Personally, I wouldnt use it in my forks, its not designed to be in our forks, its designed to be in an automatic transmission. One of the most important proporties of oil is its viscosity, just like engine oil, its pourpose/function/abilities are calculated according to it. Strangely enough, ATF doesnt have any viscosity indicator on it but most of you know it varies greatly with temperature...
(Sold back to Maximan)
The only place I use AFT, other than the trans, is if I have a leaky power steering system. Only other time, was when I added a quart to a full tank of gas in my jeep to see if it would prolong the life of the fuel pump which became louder than normal...didnt work.
