Sea Foam?
  • ikeholt40
    • 17
    you can find it all walmart for 9 bucks. Use as directed. I tried to use a little extra and it ate through the primer bulb on my weedeater.
    jb
      The stuff is great I use it in most everything I own that burns gas!
      • perurider
        • Apr 2010
        • 121
        • Peru, Indiana
        LOL, I just seen this on Amazon for 5.99 a bottle, I think a pint...you mean its better yhan STP gas treatment? for .99 cents/bottle
        '79 XS 1100F
          Originally posted by Brad
          Has any one tried something called sea foam? In was told that some bike mechanics run some through older bikes.
          Hi Brad,
          NAPA / UAP stores carry it in Canada. I expect other auto
          stores would have it too. Quite popular here at channel 11 as you can see.
          • Poprock
            • Apr 2005
            • 594
            • Oregon Coast
            Sea Foam is good stuff. Like said above, everything that runs on gas can use it. It's even good for diesels too. Sometimes you just have to clean carbs, but Sea Foam can get you home. Scooter guy/small engine shop in Stillwater OK keeps it by the case, swears by it. He uses it to free stuck pistons in little 2 smoke engines, and lots of other applications.
            I found it by accident, but have used it on purpose ever since.
            • Brad
              • 136
              • Regina, SK CANADA
              Thanks all for the great advice, trying it out now.
              Some make 'em, most just make payments on 'em!
              1978 XS 1100E
              Vance & Hines Slip on Straight Shot Exhaust
              K & N Air filter
              Home built forward controls
              Vulcan Mustang seat
              A little chopped
              http://s812.photobucket.com/albums/zz42/Brad_099/
              • Montreux_Blue
                XS-XJ Guru (Deceased)
                • 1143
                FYI, if you put it in your oil, only run it for 5 to 10 minutes and then do an oil change and replace the filter.
                Famous Myspace quote:
                • Welsh1100
                  • Apr 2009
                  • 40
                  • Fairfield, California U.S.A.
                  SeaFoam
                  My 79 xs1100f standard has a 5.3 gallon fuel tank. I use SeaFoam (a full can) in a full tank of fuel every 4-5 thousand miles with no obvious ill effects.
                  Some days you're the pigeon..and some days you're the statue/
                  1979 XS1100f
                  Saddle bags, small wind screen and non-original rear shocks. Otherwise..completely stock.
