I am in process of changing out my swingarm and doing the final drive mod. I wanted to powdercoat the final drive before installing. After pulling the gears out I found roller bearings for the shafts instead of ball bearings.
My question is- are these bearings made of the same stuff (unobtainium) as the rear wheel bearing?? I sure don't want to mess with them if they are as there is a good chance of tearing them up getting them out. Anyone else gone there before? I really don't want to experience it myself.
For those that don"t know, you have to remove bearings and seals (and anything else 400 degrees F will damage) before powder coating.
BTW- Have to change out the swing arm to continue to run the 140 tires I have. Ground out a spare (removed .04/.06) and have it powder coated and ready to install.
