Advice from the Masters
  • whiskey pete
    • 40
    • Houston, Texas
    I have all my parts together to reassemble the top end of my 79 XS1100SF. Could not afford the bore but current pistons are in limits. New rings, Valve seals, all valves are true, platau hone on cylinders, head and cylinder maiting areas resurfaced, valves lapped, ports polished.
    First time I have put one of these back together, Any suggestions, tips, watch out fors, better methods, or I learned the hard way.
    There is a ocean of knowledge out there. anybody want to give up a cup.
    By the way, I have a set of front signal blinkers that are free to a good home. Not a bribe, just in the spirit of a great site.
    If you've got any buddies, it would be money ahead to get 3 of them over to help with getting the cylinders down over the pistons. Get the gaps positioned right, then get one guy to squeeze the rings in and guide each piston. I've used different ring compressors, but this is the best method I've found. The rings are very brittle and will snap easily from an up or down movement if they come out of the piston groove.
    If you don't have 3 friends, hopefully you know 3 people that will work for beer?
      Also, there was a very good thread posted about hot to break in a new engine/rings. Maybe someone has it bookmarked and will post it. Not your regular thoughts of how to do so.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
