Anyone know where I can find new plastic T's that joins the carbs together and the fuel line hooks to? Mine has molded rubber indtead of O rings, and after the winter they leak. Pulled them of and the rubber is cracked. Other ideas would be appreciated.
Carb Fuel Supply T
Tags: None
there should be metal under the molded rubber. Cut off the old rubber and get some O rings from the auto parts store. Correct sizing is pretty much a guessing game but they are cheap. That should seal you up. I had the same problem this yearTony
78 xs11 aftermarket 4-2 HD mufflers, whats left of it is stock. A work in progress for sure. -
Carb Fuel Supply T
Thanks for the info. i tried the O rings but was concerned that might slip off without a groove to hold them in place. Instead, I cut a piece of fuel hose and put a piece on each metal end of the tee. Worked like a charm. The vent is a little loose,but shouldn't matter. Got the bike back together and rode away, no leaks. Thanks again.
RickMc
<ricks.mailbox@charter.net>
1978 XS1100EComment
Carb Fuel Supply T
Had the same problem with my 79 XS1100F. I had the same concerns with O-rings. Took care of it by gooping them up with some Permatex. Works like a charm; stays pliable and cleans up with lacquer thinner.'79 XS1100F
reincarnating after 10 year idle
103K miles
