I was hoping (and honestly believing) that I would have my XS running tomorrow or Thursday and now I don't think its going to happen.
I was out working on it today and it decided that it would not idle for me unless I had the choke on full and then suddenly it just died and wouldn't restart. In the mean time while I thought about that I pulled the rear master cylinder off to clean it and found it to be completely rusted, I cant even get the thing apart. I am in the process of trying to chisel out the snap ring because the ears have rusted off of it and it is rusted into the channel (still haven't gotten it out but have given up for the night). I then figured I would do one thing that would be a quick fix to make me feel better. The horn was loose so it wasn't grounding tightened that up and tried it, nothing. Went to check the fuse and saw that the main fuse was loose. went to put the fuse back in and the clips holding it in snapped off
I really did not want to change out the fuse block at this point but I guess I really have no choice at this point. I bought this bike less than 2 weeks ago. The thing was in great shape figured it would be a quick cleanup and it could be a work in progress daily rider. Its not turning out to be that at this point.
Now for the questions. (I am too pissed to think for myself right now)
1) Anyone have any suggestions for the poor idle and suddenly dieing?
2)Is there anything I should look out for when I change out the fuse block?
3)Is there any method to drilling out the airbox, or is it basically just cut out on the bottom side inside the filter area?
This ends my rant. Thanks for listening....
not a pretty outcome.
You could put a booster battery on it while idling. Also, check your battery, recharge it, and then with it running, check the charging voltage at idle and then at 2500 rpm, should be 14.5 volts, if still near 12, then it's not charging, will need to trouble shoot that as well. Along with replacing the fuseblock, check, clean the 3 large white plugs BEHIND the fuseblock, they are from the ALT!
