Minds Needed For A Question
  • Winterhawk
    • Jun 2004
    • 684
    • Missouri
    For the last 2 weeks since I've been riding and working on my 1978 XS1100 with 36,000 miles. I've been stumped. I've spent about 40 hours on the XS1100 trying to figure out why the number 4 plug is dark and pretty much dry black. I've replaced the choke valve even. I pulled the exhaust hoping to find the exhaust port plugged. Nope. The decided to once again pull the carbs for the 15th time probably. What I found was the sync tube has slipped into the intake about 1 inch. Would this cause it to want to suck in extra fuel or restrict air? Bernoulli's Principle? A 1/4 inch tube 1 inch into the intake would have what effect? Can't ride it yet and need to bead blast the plug off first to see if this fixed it. It would also cut out and sputter at a 4 to 5 thousand rpm band with some throttle opening up. I think that this is the result of to much fuel gong into the 4 cylinder. Carbs are perfect. Compression is 160 warm. pickups good. fuel visible at 3 mm before joining surface with the float height set at 25mm. The other 3 plugs are clean. Even traded the 1 for 4 plugs wires so ruled this out. This bike was built at Merriam Cycle about 6 years ago and has performed great till now.
    If this fixed it then we all could learn from this as it could happen to others. I think my tube pulled out a while back and I pushed it back in without comparing the height against the other 3
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Sound to me like
    you should consider replacing those intakes.....JAT
    My Photo Bucket
    • petejw
      • 2269
      • sydney australia
      if anything that would probably cause it to run lean,
      as it would want to suck in air, id pull it back up and put
      some sealant around it.
      Is the engine blowing smoke or burning oil?, im running
      my parts engine atm which has worn rings, either 1 or 4 would foul, if i had it running on the rich side.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        Needle position? I had a similar issue with one a while ago. Mine are the 81 models with non adjustable needles. I had put the needle back in the wrong order (spring and washer on wrong side). Corrected that and the issue went away.
        • thewiz
          • Oct 2006
          • 1115
          • Wilksboro, NC
          Hmmmm ...
          Seems unlikely that the needle position could have changed unless you've had that slide assy. apart and if so; recheck it.
          But ... jet needles do wear ... that may cause it to run slightly rich.
          80G Mini-bagger
          Past XS11s
          • Winterhawk
            • Jun 2004
            • 684
            • Missouri
            I was wondering if the tube in the intake could increase the velocity thus pulling the slide up sooner and or farther then the other 3 at given RPM and maybe coloring the plug. It's not the rings and it passed the leakage test with the same as the other 3 which are white. New jets and swapped the needle in #4 to be sure. Raining to hard to test ride it and will for the next 3 days.
            • thewiz
              • Oct 2006
              • 1115
              • Wilksboro, NC
              seems unlikely to me that ...
              the loose tube could do that... I think it might cause a lean condition instead.
              I think you could try to fire it without the airbox while watching the slides though, if you thought they were not all lifting equally.
              Are the float valves all new or have you swapped any of them out yet?... and no chance of a slightly fuel-loaded float, right?
              A few of us have had loaded floats before.
              80G Mini-bagger
              Past XS11s
              • Winterhawk
                • Jun 2004
                • 684
                • Missouri
                I did run it with thhe airbox off on the lift. They all moved fine. The tube is very tite. I had to sqeeze pretty had with channel locks to get it back into the hieght it should be. It runs awsome on the lift. Just the black dry coating on #4. No leakage at the tube.
                I think the mixture going around the 1/4 inch tube causes an increase in vellocity. Like more fuel mixture. Maybe it affects the slide diaphram height pulling more fuel from thhe needles some how. We will find out when ever I get to ride it.
                • Winterhawk
                  • Jun 2004
                  • 684
                  • Missouri
                  It's the best set of carbs I've ever built. I even check the fuel level height on the outside using see through tubing. New needles and seats. All jets, floats and other parts are mostly new Mikuni. The compression on number 4 was somewhat higher then the other 3. Hot, I got a reading of 168psi. I thought it was carbon build up causing higher compression level over 158psi that the other 3 registered at.
                  • thewiz
                    • Oct 2006
                    • 1115
                    • Wilksboro, NC
                    see what you're sayin about the tube now ...
                    Maybe it is carbon ... while you're waiting for the rain to stop, maybe pour an oz of MMO down that hole and let is soak for a few days ??? That stuff eats built up carbon good.
                    80G Mini-bagger
                    Past XS11s
                    • SFerinTEXAS
                      • Jun 2006
                      • 877
                      Put clean plugs in 1 and 4, switch plug wires and see if it switches problem to no 1. May not be a fuel problem
                      79SF
                      XJ11
                      78E
                      • 79XS11F
                        • Jul 2006
                        • 3563
                        • Ottawa, Ont. Canada
                        It might be ... Dry carbon Fouling This is from NKGs site on plug conditions.
                        They show a photo of a plug covered in dry carbon and say ... Although there are many different cases, if the insulation resistance between the center electrode and the shell is over 10 ohms, the engine can be started normally. If the insulation resistance drops to 0 ohms, the firing end is fouled by either wet or dry carbon.
                        Link
                        Rob
                        KEEP THE RUBBER SIDE DOWN
                        1978 XS1100E Modified
                        1978 XS500E
                        1979 XS1100F Restored
                        1981 Suzuki GS1100
                        1983 Suzuki GS750S Katana
                        1983 Honda CB900 Custom
                        • Winterhawk
                          • Jun 2004
                          • 684
                          • Missouri
                          I did this and 4 still reads the same. I am hoping it was the sync tube. Carbon, my high compression? We will see if the monsoon ever lets up. I need accell coils. 6 ohms with a resitor? I forgot?
                            • 5062
                            Would the sunk synch tube cause a rich condition of the plug? I say no. That tube should have nothing to do with richness. Maybe a sinking float, a leaking fuel valve seat, the need to vacuum synch the carbs, if it is a problem at low rpms then maybe an adjustment of the pilot screw, or problems with the exhaust ststem.
                            • Winterhawk
                              • Jun 2004
                              • 684
                              • Missouri
                              I used a set of the K@L gages ( The cost a bunch)and used a vacuum pump to check calibration. Picked up that trick from this site. The mixture was set using Brady's from Merriam Cycles way of lean best idle setting. Turn them in till RPM drops, back it out slowly until the engine sounds like it's the smoothest. Then turn it in a little until there is no difference. Seems to work great. Wished I had an EGA machine to check hydrocarbons and co% of each individual cylinder.
                              Still frigging pouring out
