Why are my carbs leaking?
  • tri650
    • Feb 2010
    • 89
    • St. Louis, MO
    OK, I wanted to take the left hand switch controls off of my donor bike (79 xs) and had to lift the tank to disconnect them. As soon as I did the carbs started to leak at the petcock - because the hose was crimped. Fixed that but now gas is leaking out the bottom of the airbox. All I did was move the tank - what could I have done to get gas leaking out of the bottom of the airbox?
    _____________________
    78 XS1100 - mainly stock
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Possibility
    Hey tri650,
    It could be that the lines were plugged up, and when you moved the tank and repaired the broken line, the fuel flow was restored. Your floats are probably stuck open, hence the carb leaks.
    IMO, I would just empty the donor bike tank. Keeping the fuel in there will lead to nothing good.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    • Cyclechrist
      • 13
      • Bedford MASS
      Leaking out Air box
      Yes i would say you need to pull your carbs,tank,and all fuel lines.
      Carfuly clean your carbs (inspect your flotes) then check your flote leavel.
      • Cyclechrist
        • 13
        • Bedford MASS
        Float Height setting
        go to
        this will give you your float height.
        But first just a good cleaning may fix the fuel leak.
          Originally posted by Cyclechrist
          go to
          Your link isn't working.
