Quad piston caliper blues (continued)
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    I got back to working on or rather reworking the SOS Suspension R1 caliper brackets for the XS11 standard. Originally the spacers that came with the kit to move out the rotors to center in the new calipers were way to thick...
    My solution was to have the right amount machined off the brackets so they would set the calipers in closer to center the rotors in the calipers. I have to say I admire those that get the R1 calipers to work with stock XS11 rotors. I haven't been able to do it yet.
    It seems I measured or added it all up wrong since I was off by .7mm... My solution for now is to use thinner disks. I have some 5mm thick rotors from another bike that have the right offset and diameter and I'm going to send them out to have the centers opened up and drilled for XS11 wheels.
    I don't think any of my observations are all that useful to others but I needed to vent... I feel like Microsoft, by the time I get this to work, it should be great...
    Tony
    • 8894
    That will be a good mod, some sweeet stopping power. I'm interested in this.
    • Geezer
      • May 2003
      • 2985
      I've never been thrilled about the stopping power of most early 80s and older Japanese bikes. Back then I had a Guzzi T3 that would stop on a dime and spit out change and I really miss that kind of stopping power.
      It turns out 1999~2000 CBR600 rotors have the same diameter and offset but the bolt holes are too small and too close in. However there is enough meat to rotate it 1/6th of a turn and drill all new holes... These rotors are about 1/3 the weight of stock XS11 rotors and are already cross drilled.
      If the CBR rotors I bought off eBay are OK when they arrive, I'm going to send them out for the required machine work. I don't trust myself to get them spaced correctly and concentric... I can get new EBC rotors at dealer cost but I'm too broke for that...
      Geezer
        Heh heh.... yep, change one thing and other things change, just like ripples in a pool.
        Can you post some pics? I'd be curious about those rotors (thickness, hub hole diameter, etc) too.
        '78E original owner
        • Geezer
          • May 2003
          • 2985
          I'll take pix when I'm done. The center hole in the CBR rotors are about 2mm too small and will have to be opened up on a lathe. Fortunately I've found a guy here in town that does this kind of work.
          I'm looking into getting the caliper brackets drawn up so I can get a quote from eMachineshop.com. If the production costs aren't too bad, I'll have some made up... I could make them here but I would need a new band saw and an oscillating spindle sander. I don't mind buying more equipment but I don't have room for them in my shop...
          Geezer
          • Geezer
            • May 2003
            • 2985
            I made 1 new bracket for the R1 calipers out of 1/2" thick aluminum bar stock and to toot my own horn, I think mine is better than the ones from Australia. I made it in a rather Burt Munro fashion using my band saw, drill press and belt sander. Making a second matching one for the other side is going to be a trick unless I send it out to be cut out by water jet.
            I still don't know if the cost of making them would be worth what any one would pay for them. I like the idea that the calipers are still Yamaha parts and pads won't be hard to find. it looks like the FJR1300 calipers up to 2005 are the same as the ones on the early R1. I will be looking for a pair of FJR calipers to make sure. If this is the case it may be worth offering the brackets for sale but the price will be around $100 pair and I don't think too many XS riders would pop for them.
            I will be dropping the CBR rotors off at the machine shop tomorrow to have the center opened up and the new holes drilled. When I'm done I should have a couple pounds less unsprung weight and more stopping power. I'm stoked just thinking about it...
            If nothing else this has been an interesting journey...
            Geezer
            • Geezer
              • May 2003
              • 2985
              Progress
              I bolted the calipers and the mounts up to a pair of junk fork legs this morning for pix. I won't have them mounted to my bike for at least a week. I've got to much going on and I've had to squeeze the work in on these between other projects...
              warning, this pix are not dial up friendly...
              The stainless bolts I used to mount them to the fork legs are too long and will have to be shortened or replaced and the adapter plates will be painted black before they go on my bike.
              If I can either farm out the cutting of the adapter plates or get some better equipment for the task, I may consider offering these for sale. As it is now, they're way to much work to make. I'd be willing to supply a cardboard cut out so you can make you own for the cost of postage...
              Geezer
              • CatatonicBug
                • 6117
                • Clinton, UT
                You could just make a drawing of it, and post it here, so folks could print it out for themselves. Just like the printable middle/final drive dipsticks.
                • Geezer
                  • May 2003
                  • 2985
                  I'll talk to Yaman about doing that. I can't draw worth shiite.
                  In the meantime, I've bought another set of 1999 R1 calipers and I'm going to make one more set of plates after I've tried a new blade in my band saw. If it makes it easier to cut them out, I'll consider making them on special order. I have enough aluminum to make a few more sets...
                  Geezer
                    Hey Tony,
                    Looks nice, but why all the fancy curves...asides from aesthetics?
                    I would think straight line cuts would be easier and quicker to make, and still not look bad!? JAT!
                      Hey Tony,
                      Says the guy with an Octogon deck!!
                      • T99Ford
                        • 678
                        • Bozeman,MT
                        I think aesthetics are the reason! Those look really nice, man!
                        Healthy is merely the slowest rate at which you can die
                        Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
                        • Geezer
                          • May 2003
                          • 2985
                          The curves on one side are for clearance and the ones on the other side are for weight reduction. It was either that or drill some holes in it. What would have looked the coolest. would be to sculpt it out but I don't have a milling machine. In the end, I did what was easiest...
                          Given better cutting tools, it would be even more curvy but since I did much of the work Burt Monro style. I got it to this point and decided I worked on it enough.
                          Geezer
                            • 8894
                            Adapter plate looks good, Geezer. I know what a PITA they are to make with limited tools.
                            • Geezer
                              • May 2003
                              • 2985
                              I had my wife talked into getting the equipment to make these but my shop is already too F'ing small and I don't know where the hell I'd put it.
                              I have my fingers crossed that I can finance a new place with a bigger shop but at the moment it's looking like a long shot...
                              Anyway I'll be looking for stainless caliper pistons for these and some sintered brake pads too...
                              Geezer
