oil delivery pipe mixing bolt?
  • R.S.
    • Apr 2010
    • 24
    Hey all.
    Just adjacent to the oil delivery pipe, is a bolt that screws into the tranny housing, and I need to know what its supposed to be set at - buddy of mine thought it was the cam chain tensioner - does this have to be set exactly correct for the oil to have the proper pressure for the head?
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Originally posted by R.S.
    Hey all.
    The cam chain tensioner is in the front of the engine between #2 and #3 exhaust pipes. Its the only thing on that side about 6 inches or so down from the valve cover... Im not exactly sure of your reference but if in fact you are talking about the cam chain tensioner then my advice is dont try to do an adjustment without following the manual! Valves are easily bent if not followed. You can download an OEM and aftermarket one from member Catitonicbug's signature. GL and welcome to the site.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • R.S.
      • Apr 2010
      • 24
      I know what the cam chain tensioner is
      the silver bolt just below the lower end of the oil delivery pipe, sticking straight up
      • b.walker5
        • Feb 2009
        • 1745
        • Invercargill, New Zealand
        I think he's talking about the external oil line at the back of the cylinders, from the crankcase to the head but I'm not sure what bolt he's talking about. Apart from case and starter bolts, the only thing I can think of back there is the oil pressure sender.
        • b.walker5
          • Feb 2009
          • 1745
          Ok, You beat me to it. Directly behind the banjo bolt for the oil pipe you should have an oil pressure sender with a wire attached to the top of it. If you just have a bolt then some PO may have removed it and plugged the hole. Check here for what should be there...
            Pic link is no good, but assuming you're talking about where the oil pressure switch goes on the XS, or hmmm... Brain fart if it's an XJ. Any bolt/screw/sensor there is plugging a hole and has nothing to do with how much oil goes up that line.
            • R.S.
              • Apr 2010
              • 24
              this pic work?
              ok.. we have an external oil line at the back of the head, it goes into the lower engine case, just next to this is a vertical silver bolt in the "tube" at the tip of the case, seems to be a mixing valve of some kind, for oil
              its in the 32'd picture down at this page
                Nope, pic still doesn't work. If you go to the pic in Photobucket, hold the mouse over the one you want for a sec, a pop down box will appear. highlight and copy the last option that it says, then paste that in your message here.
                • b.walker5
                  • Feb 2009
                  • 1745
                  First link still doesnt work but the other pics show a bolt where the Oil Pressure sender/switch should be.
                    +1 b.walker5 said.....and again, oil pressure sending unit missing where bolt is.
                    • WMarshy
                      • Apr 2009
                      • 2402
                      • Mexico NY
                      Sounds like everyone is on top of the issue. I just wasnt sure about what you were calling "adjacent" and didnt want you to "open pandora's box without knowing how to close it properly" if ya know what I mean.
                      '79 XS11 F
                      Stock except K&N
                      '79 XS11 SF
                      Stock, no title.
                      • XJOK2PLAY
                        • 2099
                        • Skiatook, Ok.
                        It would have to be an XS, Tod, to have an Oil pressure sending unit.
                        XJ's just have the oil level switch down in the pan, right?
                        I just looked at mine closer and I see there is a bolt in my XJ's block there, but it's all the way screwed into the block... just the head can be seen. That bolt I see in your pic looks really long...
                        Does anyone know from experience if an oil pressure sending unit installed there on an XJ works accurately for an electrical oil pressure guage as well?
                        I'd like to install one...
                        2011 Kaw Concours 14 ABS
                          Yeah, I knew the XS had the sending unit there, I was just trying to remember off the top of my head what the XJ has there.
                          The pressure gauge won't work with the XJ gauges. You might be able to set up an aftermarket gauge up on the handlebars or dash somewhere and make it work that way though. I'm like you... I would rather have an oil pressure switch versus an oil level switch.
                          • XJOK2PLAY
                            • 2099
                            • Skiatook, Ok.
                            Definitely! Is the XS sending unit the only one that will work, or will any generic automotive unit do the trick?
                            I'd just add the guage into the faring, like I recently did w/ my Voltmeter.
                            Who knows? I might do the trick one day that Cody did to 'Zilla... remember? He'd installed a Vetter sound system unit in his faring, (w/o the sound system) and made a blank sheet metal panel to fill the holes, and installed all his guages there. It looked like the cockpit of a fighter plane... complete w/ altimeter! LOL
                            Seriously ... we should do this mod, ya know? That way, we'd have both guages... pressure & level.
                            • WMarshy
                              • Apr 2009
                              • 2402
                              • Mexico NY
                              All you need then is Oil Temp...
                              Not a bad Idea, I wouldnt mind workin a PSI and Temp gage into the cluster some where.
                              '79 XS11 F
                              Stock except K&N
                              '79 XS11 SF
                              Stock, no title.
