Just another charging thread...
  • dpotter58
    • Aug 2004
    • 1865
    • Southern Maryland
    I started having a problem with my headlight not coming on while running. During the “troubleshooting” I found that if I wiggled the wires under the tank it would come on. In pulling the wires apart, I found the wire for the diode wire was broke so I pulled the diode out, plugged it together, put some heat shrink on it and went about my business.
    Soon after, I had a dead battery and since it had been fine prior to the headlight issue, I checked the charging and was only getting ~11.8 volts even at higher rpm.
    My tach works, wires for the stator checked good so I kept looking for a problem.
    What I found was the omron relay 3H5-00 was very hot. As soon as I unplugged it the voltage went up to a little over 12 and when I sped the engine up, the voltage went to about 13.5 or so.
    I bought some deoxit and cleaned up a bunch of the connectors in the headlight and charging circuit but when I plug the relay in it heats up and voltage drops. I had another relay from a charging bike and and plugged it in but found the same problem.
    So, is this a problem of not having the diode and if so what size do I need to get? If not, what else could it be?
    1980 LG
    1981 LH
    • 8891
    Might want to check the alternator connector behind the fuse panel, they corrode and sometimes melt. If you unplug the headlight relay and jump red/yel and blu/blk, the headlight will come on with the key.
    • dpotter58
      • Aug 2004
      • 1865
      • Southern Maryland
      Yep. It was one of the ones I pulled and cleaned. It's good
      1980 LG
      1981 LH
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        That diode is part of the circuit that holds the headlight on after the engine has started, until the switch is turned off.
        It may be allowing a draw in the opposite direction. I would suggest taking the old diode into a Radio Shack with the geekiest looking nerd working there and ask him to set you up. Most of the time you want to find a Radio Shack that doesn't sell cell phones. Most any electronics supply shop would have it as well.
        Just be sure to install it the right way. They usually have a stripe on them to indicate the positive side, so make sure it goes in the same way as it came out.
        Ich habe dich nicht gefragt.
        • dpotter58
          • Aug 2004
          • 1865
          • Southern Maryland
          If I hadn't been a dumb azz and tossed it I would. I found a thread with the correct size. I'll pick some up tomorrow
          1980 LG
          1981 LH
          • randy
            • Dec 2003
            • 4521
            Dwayne any diode above 1amp will do. Install it with the striped end toward the relay. Last time I was at the shack for diodes they had a pack of two 6amp for a couple of bucks.
            • dpotter58
              • Aug 2004
              • 1865
              • Southern Maryland
              Do you think the lack of the diode is the problem?
              1980 LG
              1981 LH
                Could be. The White wire with the diode supplies pulsed 12V DC to the headlight relay to turn it on when the engine starts and the charging system begins working. Once the relay is on there is a second diode inside the headlight relay that keeps the relay coil energized from the RLU side of the relay.
                When the headlight relay is 'latched' on, the diode on the White wire now isolates the Regulator/Rectifier and the stator from the DC voltage being supplied to the relay coil by the internal diode. There should never be any DC in any of the White wires from the stator.
                If the diode on the White wire is shorted or replaced with a jumper the headlight relay will feed 12V DC back through the stator and the Regulator/Rectifier.
                Don't do that.
                Regards,
                Scott
                • petejw
                  • 2269
                  • sydney australia
                  hey dpotter58,
                  ive had this problem for ages and have never found a fix,
                  the light would work ok for a while then not work at all, most of the time wiggling the wires on the left side of the tank would fix it, last time tho
                  it went out 4 ages and i had to tape the 'pass' switch down
                  to have a light, its still does it occassionally,
                  if you find the problem
                  id sure like to hear about it.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                    It is just one more good reason to trash the locking relay system and install an automotive switchable relay in its place.
                    • dpotter58
                      • Aug 2004
                      • 1865
                      • Southern Maryland
                      Putting in a new diode did the trick. Thanks for the info... You folks on channel 11 are the best. Well, some of ya are
                      1980 LG
                      1981 LH
                      • cywelchjr
                        XS-XJ Super Guru(Deceased)
                        • 4450
                        • Sacramento, CA
                        The locking relay works just fine as long as everything is working properly. A common failure is the diode in the harness under the tank. Replace that with a nice new one and if the charging system is working things will be fine. It's one of your first signs that the charging system is not working, that the headlight doesn't come on.
                        • petejw
                          • 2269
                          • sydney australia
                          can someone tell me where abouts this diode is situated,
                          is it wrapped up in the wirering loom?
                          tia
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • dpotter58
                            • Aug 2004
                            • 1865
                            • Southern Maryland
                            under the gastank look in front of the regulator in the harness you will see a white wire under the tape, mine was looped in the bundle near the reserve lighting device. The diaode is in a clear plastic protector kind a thing...
                            1980 LG
                            1981 LH
                            • petejw
                              • 2269
                              • sydney australia
                              thanks for that.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
