Carb guru's wanted
  • RODS454
    • Dec 2009
    • 83
    • Midlothian, Tx
    Carb guru's wanted
    OK, started rebuilding some carbs I got from one of the members on this site.They appear to be off an early model bike as they have the long idle adjust knob and 137 main jets. Anyway I disassembled them and removed everything I could get off, or out. The main nozzles, part #6 on the exploded view are two different types. Two have 16 holes and two have 10 holes. Of course I didn't pay any attention to which came out of which carb body. Do the ones with 16 holes go in the center two carbs? Maybe to allow a little more fuel to cool those cylinders. Kinda like larger jets in the center on later S models? Just a guess on my part. I didn't realise they actually came that way, but what do I know? The carbs don't appear to ever have been disassembled this far before. They are in really good shape. I'll post some before and after pics when I'm finished. My question is which main nozzle goes in which carb?
    Thanks,RODS454
    "I'd rather be fishin'"
    1980sg "Cruise Missle"
    2002A Goldwing
  • XSokieSPECIAL
    • Jun 2009
    • 1631
    • Tulsa, OK
    I believe your right about those nozzles. I've got 79 carbs on mine but I never removed those but what you are saying DOES make sense.
    Someone will come along that really knows , I'm interesed too.
    • RODS454
      • Dec 2009
      • 83
      • Midlothian, Tx
      By the way
      Does anyone have the throttle lever for a set of carbs. The PO removed the swivel part that the cable end attaches to. It looks as if you have to seperate the carbs to remove the lever. I'll figure that out if I get one.
      Thanks, RODS454
      2002A Goldwing
        • 8866
        Emulsion tubes (main nozzle) carbs 2+3 less holes, carbs 1+4 more holes.
        • tadtl1
          • Mar 2010
          • 98
          • Auburn Mi
          like Phil says
          Hi,
          I do believe that the more holes allow more air to mix with fuel, therefore, the emulsion tubes with more holes should be in the cyls that run leaner, therefore , one and four, OR, LIKE PHIL SAYS.
          80 MNS , Georgefix pods , crossed fuel lines, no octy, inline filters, Daytona handlebar, custom seat, Hardley 19 muffs
