My "Rusty Hammer"
  • RockinD
    • 47
    • Lake Oologah
    My "Rusty Hammer"
    OK, so I think I'll give her that temp name as you can see.
    Got my work cut out for me, and just getting started.
    Connectors and wire came today (Thanks, Geezer) and I borrowed a friend's camera to document what sad shape she's in.
    [IMG] [/IMG]
    So, wish me luck. Realistically I'd like to have her up and purring by Mem Day, then go to work on all that frelling rust!
    Please offer suggestions or pose a question that may make me take another look at something anew.
    Doc
    '80SG 'Velvet Hammer'
    '80LG 'Black Velvet'
    "Friends don't let Friends go Fat"
    finitum non capax infiniti
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    First thing to do is confirm that the rust your looking at is only surface rust. Surface rust can be dealt with easy enough. However more serious rust to the frame is BAD NEWS. Check the lower frame tubes for integrity. Check the side stand side closely as it tends to rust through sooner then in other areas.
    I would strip it down to the frame, do the harness off the bike so you can do a good job of it. Check the frame out while it's striped then rebuild the bike cleaning and replacing as necessary as you go.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • RockinD
      • 47
      • Lake Oologah
      Well hell, you just ruined a good plan. No, I know you're right. It's just that I am borrowing the corner of a neighbor's garage to do the work presently and haven't had a chance to broach the long term aspect of this with him.
      What are my chances of finding a suitable frame replacement if mine has got the creeping crud? I mean what'll work? Did get a 249 schamolian quote on shiny new forks but not sure about that need so far.
      Out of curiosity, why do the harness off the bike or is that just if I am doing a total off frame I will need to anyway? I've already begun pulling bolts and screws off and cleaning those up so they seat properly along with cleaning the M/F contacts for the connectors.
      Bought some cheap wire leads for a multimeter in case I need them for pickup coils. Still need to figure out what to do with those cloth stator wires, though.
      So, far just able to nibble away at the small stuff really. Time has a way of getting in the way of important stuff like fixing our bikes, you notice?
        The 3 cloth-covered Stator wires can just be covered in a single piece of heat-shrink tubing. No real need to take the harness all th way off, unless you were planning to tear the whole bike apart. I think though, with all that rust, you may want to do that, and get ALL the rust off the frame and have it re-painted or better yet, powder-coated.
        • XSokieSPECIAL
          • Jun 2009
          • 1631
          • Tulsa, OK
          [IMG] [/IMG]
          Doc
          Give me a holler if you need anything.
          I ain't far away and I BTDT.
          Got a couple extra parts and a pretty good line on finding anything you need.
          • 79XS11F
            • 3563
            No, the harness does not have to come off the frame to give it a going over but if your going to address the frame the harness should be coming off.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
            • mack
              • 2411
              • Ontario, Canada
              space
              I have to agree with Rob on this. Some of the connectors are difficult to get at well enough to do a good job on them. Get the rust off all the frame soonest. If you don't, what your looking at now is the best your going to see. I found that the rust likes to get up into places you can't usually find without the frame bare. As a side point, mine was WAY worse than yours.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
              • RockinD
                • 47
                • Lake Oologah
                @Mack- Gee, that cheers me up a bunch! lol It is good to have some idea on a regular basis as to what's going on with these mosheens. I can take courage that no matter how daunting the task, however bleak the present, how many mosquitos you are batting, whatever the future holds.... (vinyl record scratch)
                Sorry, got carried away. No, I surely appreciate whatever you guys have to offer and am glad I can be a XS man. hahaha
                Anyway, here's the close up of the cloth wire CBug. It's pretty chewed up as I noted in a previous post.
                As to this rust issue, I remember doing magnafluxing to machine parts back when I was a newt, it showed any stress cracking or imperfections in the metal casting (but don't know if it'd work on tubular steel). I think I remember that being part of the 'non-destructive' inspection performed by USAF techs along with Xray, as well. I wonder if any Tulsa area machine shops have Mflux capacity that would/could check for this if it would be feasible and Cheap.
                (Hey, XSOkie- what'ya think?)
                Again if I'm left with great green gobs of ooey gooey gopher guts for a frame-what do I do?
                • XSokieSPECIAL
                  • Jun 2009
                  • 1631
                  • Tulsa, OK
                  RockinD
                  Check your PMs
                  • XSokieSPECIAL
                    • Jun 2009
                    • 1631
                    • Tulsa, OK
                    Sorry....
                    4R1 is a standard frame.
                    • RockinD
                      • 47
                      • Lake Oologah
                      Stress cracks
                      OK here's a new one to me.
                      Talking the other day to an old mechanic and the topic got around to my bike (My fav topic) and all the rust and whatnot. I told him I was gonna be doing a thorough cleaning of the frame since I wanted to check for any weak or potential problem areas. Here's what he told me to do:
                      After I brass brushed it down at the joints or any suspect areas I should wipe it all down with a clean rag or two and some kerosene. Then, dust some flour
                      over those spots I am concerned about. Apparently and according to him the flour reacts in any fissures with the kerosene that hasn't evaporated leaving tell-tale tracks.
                      It sounded simple enough and so tomorrow Imma gonna try it. I'll keep you posted on the outcome.
                      Anybody ever try this before chime in on what you found out.
                      • XSokieSPECIAL
                        • Jun 2009
                        • 1631
                        • Tulsa, OK
                        Nope....can't say that I've ever used flour to find a crack......LOL....
                        • jmnjrpa
                          • Jun 2009
                          • 863
                          • Lewisville, Texas
                          Yeah
                          That will work on major cracks but the starting cracks may only be visible with a mag partical or Zyglo inspection. Zyglo is cheaper and also works on non ferrous materials (nonmagnetic).
                          '81 1100 MNS - "Midnight XSpress"
                          Original except:
                          Big John
                          • RockinD
                            • 47
                            • Lake Oologah
                            Happy Mom's
                            hahaha
                            I dunno, I had a GF once that Loved baguettes. Notice I said "once".
                            @jmnjrpa
                            How does one go about finding Zyglo, without ixquickin it? Is there a National Association of Zyglod's? Do they have conventions?
                            Or, perhaps a Zyglodian Fellowship. hmm, so many things to ponder.
                            OK, so enough levity. I did not get time today to start the hunt for weak spots using the flour method.
                            I did get some good cleaning in on the frame, removed and soaked some rusty screws and bolts along the port side (that's left for you lubs) and worked on doing a good survey as I went along. Only real change from that is removing the tail/stop light assmbly.
                            Which brings me to a question. How can I remove each socket to get at the wires to replace them? (I just now got in and wanted to put this down on here before I got extra stupid tonight.) I'll look for the info here in a minute to get totally up to speed, but are there any tricks?
                            Am I gonna run into a problem re-soldering and should I just get new sockets? (the bases appear clean and dry) That goes for the rest of the running lights, too, I guess.
                            Like, what's the easiest/fastest way to get the license plate lamp holde off?
                            Anyway, looking forward to tomorrow. Oh, 1 last thing. I can't find a local source to adhesive heat shrink. XSOkie may have someone around, but where on line if I need different kinds?
                            Thanks and Happy Mom's Day to ALL the Mothers.
                            • XSokieSPECIAL
                              • Jun 2009
                              • 1631
                              • Tulsa, OK
                              Hey doc......
                              Heat shrink isn't a problem, don't know anything about "adhesive heat shrink".
                              The stuff is pretty damn adhesive when it DOES shrink.
                              What "sockets" are you talking about? Turn signals?
