Plug read help & questions
650SF
XS1100SG Project bike
http://s910.photobucket.com/albums/a...t=DSCF3034.jpg -
those plugs look really good for a bike that
sat for so long,
to me no 1 looks a little lean, the others
not to bad, id put the correct plugs back in,
i wouldnt rejet it at all, just play with your mixture
screws and give it a good sync.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
and id also start with the stock plug gap.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
blue pipes
Just out of the engine my pipes are blue for about 3 inches.
Is that a reliable telltale that the bike is running lean?XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
http://s910.photobucket.com/albums/a...t=DSCF3034.jpgComment
I tend to agree with Guy, but just out of curiosity how dark is the bluing? In general blue indicates rich, gold pipes indicate lean, and the silver color are just right (sounds like some weird XS three bears tale). Problem is you can get a bike that will give you all three colors depending on how you have been riding it. Plugging around the neighborhood with the enricher out will blue them quick. Checking your plug condition after about 1k miles would be a better gauge. Personally I like to use a colortune plug to set my carbs and verify my jetting. Some people like colortune, and some people do not. I have had good luck with mine. JATI think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
Like this
I tend to agree with Guy, but just out of curiosity how dark is the bluing? In general blue indicates rich, gold pipes indicate lean, and the silver color are just right (sounds like some weird XS three bears tale). Problem is you can get a bike that will give you all three colors depending on how you have been riding it. Plugging around the neighborhood with the enricher out will blue them quick. Checking your plug condition after about 1k miles would be a better gauge. Personally I like to use a colortune plug to set my carbs and verify my jetting. Some people like colortune, and some people do not. I have had good luck with mine. JATStore your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
I was reading up on carb tune site you sent me and was going to go step by step. I was just wondering as to the bluing if I should go up a jet from the beginning.XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
hey rick,
dnt go changing jets for the sake of it,
those plugs look really good for an engine that
has sat for so long,
what were the settings on the mixture screws?
if its flat down low, you might be able to go up 1
size on the pilot jets, but id leave your main jets alone.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
3 and 1/4 turns out
I've been reading some carb tuning info, some of the words they use to decribe situations can be a little confusing.hey rick,
As I understand it if you hit the gas and the bike starts to stall then takes off that is an indication you are rich. The rings on my plugs were black. Electrode looked like white.
I guess the engine starts to flood or there is not enough air for combustion. I can see that.
I was thinking I was lean at 3K maybe I was rich so my floats were set at 23mm. I set them @ 24mm I'm setting the Idle @ 3 turns out and going to attempt to go through the tuning process Debeardsle set me earlier.
Going to pick up some proper plugs and give it a go.
So yes I'll leave the mains alone for now.
ThanksXS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
Soft and boggy on the bottom is a sign of a rich condition. If you have got the 78/79 carbs, 24mm is going to be way rich. Spec is 25.7mm plus or minus one mm. If you have got the later model carbs, 24mm should be OK.I think I have a loose screw behind the handlebars.
i agree that soft and boggy is a rich condition,
and if its flat that its lean,
sounds like you might be slightly rich on the floats,
and lean on the pilot jet,
try the set up you want go with and see how it works for you.
heres a good link from the factory pro site
with regards to the pilot jet.
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Confession time
As I'm reading posts I find references made that the needle jets on 2&3 are different than 1&4.
I buggered up the needle jet on #1 and replaced it with Part #48-0660
from Mikes XS.
Don't know if I mixed up the others.
What is the intent of the different needle jets?
To update on my progress.
I changed the oil filter and plugs.
Have not got a chance to take it for a good ride.
Want to follow the CV tuning tips but to tell the truth I'm a little tentative on revving it past 6500 RPM.
Whats your feeling on revving them that high.
The other day I was in 4th revved it to 6500 and the bike was over 90MPH.
In my neck of the woods you get a ticket over 90 and you'll have some grief.
Not to mention the crap I'd get from my kids.
It is kinda fun tho.XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
The part you referenced is an emulsion tube. It works with the slide needle, and IMHO it is not a good idea to mix them. Not all those emulsion tubes are the same, and if you get one that is metered differently than the other three you could get unpredictable results. The flow diagrams on this site might help you to understand what\'s going on inside the carb - http://www.mtsac.edu/~cliff/storage/gs/BS32SS_Carbs.pdfI think I have a loose screw behind the handlebars.
