You might be able to set it up on the center stand, run it, and use the rear brake to put it under a load.
A loose primary chain sometimes slaps around, but it's usually only going to do that at idle with carbs un-synched.
As many problems as I've had in the past with the crank bearings on these, that's always my innitial thought when I start hearing those noises. But a crank knock sounds deep in the motor, not a chain noise. An evening to pull the motor and pull the bottom case off to check on that may save you an engine case and crank. A spun bearing will ruin both. BUT.. usually you will get an oil leak out from around the crank seal before that happens.
I have no experience with a piston clip coming off, but don't really see how that would cause a constant knocking. The pin could contact the cylinder wall and rub, but there shouldn't be any constant lateral movement to speak of. The pin would stay inside the piston.. but I guess constant forces too far on one side of the piston could wallow out one side of the hole. If it was a constant and sounds up higher than a crank bearing, then I might look at that or possibly the rod bearings. Were those replaced in the rebuild? If so, were they replaced with the correct size according to the rod stamps? Those "Correct sizes" only count if there's no wear to the crank. Putting in the "Right sizes" when the crank is slightly worn, will let there be some movement in the between the rod and crank. It would last a little while, but then start knocking more and more. I had one that I replaced all the bearings on to the correct size, and 2500 miles later, they were junk.
So, if you deplete all of your non-invasive ideas about timing and such, you might look at the bearings. Just a suggestion. You could also run the motor and get things stirred up, drain it into a screen, and see if there's some copper looking shavings that don't sick to a magnet.
