Educate Me
  • Filter
  • Educate Me
    At the risk of placing myself in the, " what kind of oil do you use on your spark plugs", category, I have a general mechanical question. I read someplace that the valve seat and the shims are made from the same aloy. Presumably the valves themselves are all made from the same material, (different from the shims & seats), my question is what makes each valve train wear differently. Is it that the combustion chambers are not uniform, or each cylinder breaths a bit differently because of the flash in the ports. I dig that shims would require replacing , but I'm curious why they all wouldn't require replacing at the same time and theoretically, by the same amount?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • #2
    Gooood Question..
    Gotta be the same reason why the valve lash in the ole 350 is never the same, dunno what the reason is but it's gotta be the same, Right? Everytime I adjust the tappets in the V8 they're different. It has solid lifters and adjustable tappets and theres alway one thats a few thou out from the rest, and never the same one. (over long periods).
    This probably gets down to the pyhsics of metal, heat and pressure etc so I'm going to watch the replies with interest on this one.
    • #3
      metal has different levels of hardness.
      even a little difference will cause different wear
      and remember when you replace a shim you generally are only changing it
      by a couple of thousands of an inch
      a human hair is 3 thousands of an inch, so having 1 thousands wear on one valve and 3 thousands wear on another valve, the difference is less that a human hair
      just my 2 cents
      http://home.securespeed.us/~xswilly/
      78E main ride, since birth the "good"
      78E Parts, the "bad" fixing up now
      78E Parts the "ugly" maybe next year
      79F Parts
      80G Parts
      75 DT 400B enduro
      • #4
        the way the engine is run can also
        make a difference to how things wear,
        the faster the rpm the harder parts are opening and closing.
        also different valve train configurations,
        with over head cams (as in our bikes) valve clearances usually close
        up do to wear from the valve and seat, with older
        style engines that had push rods, rockers, cam followers, these parts
        would wear faster resulting in the gaps being larger.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • #5
          It's a feature?
          • #6
            curiosity
            Pete, seems to me that I read that the reason the shims and valve seats are made from the same material was so that they would wear the same, negating the need for frequent shim adjustments.
            I was just wondering about the different wear per valve train was related to mixture differences in each cylinder as I don't believe "color tune" was available 20 years ago. One cylinder richer or leaner than the next making one train work harder than the next.
            As I've said before, my mechanical expertise is minimal so I'm trying to learn as I go. My usual route is to get a handle on the macro before I tackle the micro.
            It certainly is a feature Ken. Last time I was in Revelstoke was to shoot down avalanches along the highway. Stayed at Rogers Pass. It was a fun couple months. Loved the scenery.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • #7
              Chaos Theory.
              There isn't a good explaination. Why is it that my Okuma Horizontal Machining center is accurate to less than .0001" but one part will be perfect and the next .002 over nominal? Why does one stock engine in a Ford truck run 250k with only oil changes and another wear out in 30k? Why are there 20 slices of bread in a SAE ISO 2009 loaf of bread, but bologna comes in packs with 22 slices? HOW MANY LICKS DOES IT TAKE TO GET TO THE CENTER OF A TOOTSIE POP?
              The world may never know.
              One thing is for sure, its a damn good think FIAT didn't make out valve train. If that were the case, you'd have to carry a full shim set with you to go to the local Sonic Drive In for a cherry limeaid. You'd have the valve cover off three times. At least that was my experience with my 78 X-1/9.
              Ich habe dich nicht gefragt.
              • #8
                Dunno, how far away is your Sonic? Ours is 15 miles (east or north two choices) away, so how many valve adjustments would that mean?
                • #9
                  OK enough
                  10W1000 you say?
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
