ok so assuming that what motoman said is true
what do I have to do now? you may have identified the problem but have not offered a solution yet.
I felt behind the clutch basket for a gear that moves and there is one that slides back and forth but not enough to come off of the teeth of the one it meshes to. from looking at the manual I believe that it is the oil pump/idle gear.
do I have to drop the whole tranny or is this a fix that I can do with just the side covers off?
what do I have to do now? you may have identified the problem but have not offered a solution yet.I felt behind the clutch basket for a gear that moves and there is one that slides back and forth but not enough to come off of the teeth of the one it meshes to. from looking at the manual I believe that it is the oil pump/idle gear.
