Hello all, been using this site for a few years now and have used a lot of useful info for my 82 XJ1100.
I recently bought a 78 XS1100 that I have ridden a bit and it uses a lot of oil. I'm talkin a litre every 400 or 500km. Nice trail of smoke out of the left pipe. The PO had owned it for 20 years and said it always had used some oil and it has gotten worse over the last couple years.
I took a compression test and it is 120 across the four. The bike runs well and no knocks, shifts well. Shows about 58,000km.
I pulled the head and jugs off. The top rings are really worn. The gaps are huge, way past spec. Second rings are ok.
Couple weird things I have questions about:
1) the top of piston #2 has a hard black build up on it, like boiled oil. This piston also did not have the oil ring gaps spaced out around the piston. They were almost on top of eachother. I'm thinking with the worn top ring and no oil ring spacing, most of the oil burning was coming from this cylinder. Doesn't appear the jugs were ever off. Never gapped properly from factory?
2) All 4 cylinders have a ridge at the top limit of the ring travel. I've measured the bores twice, come up with 71.5mm. The ridge is LESS than 71.5mm. The ridges are not carbon, they are metal. The ridges are not uniform in depth all the way around.
Any comments? I was thinking of using a ridge reamer to get rid of the ridge and honing, new rings. Thanks for any ideas.
