Ready for a blower?
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Ready for a blower?
    If not, you probably need these!
    http://cgi.ebay.com/ebaymotors/YAMAH...Q5fAccessories
    '05 ST1300
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Folks have reported that the "big bore" pistons give a lower compression ratio then stock pistons, I suspect that these are the same wiseco blank in a smaller diameter, giving lower then stock compression which is good for forced induction.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      Depends on which year of bike you're talking about. The '78 & '79 have a low-domed piston and smaller valve space in the head. the '80+ have a higher domed piston and bigger volume space in the valve area (Larger valves). The aftermarket "Big Bore" pistons are domed somewhere in between these two, so on the earlier models, it'll bump up your compression and the 80+ bikes would drop it compared to one that would have had a similar dome. That being said, if you are going with the bore kit, you're motor is probably wore out with low compression, so a new piston/rings/hone is going to greatly increase the compression you had.. no matter the year.
