Race Tech Emulators on EBay
    Just a heads up; here's a set of cartridge emulators that will fit the XS11 front forks for a reasonable price. These are listed for a Kawasaki but it's the same part number as the XS...
    http://cgi.ebay.com/ebaymotors/Race-...item2eacb1a5d9
    '78E original owner
  • yamahansolo
    • Aug 2007
    • 1113
    • jawga
    if you can get them do it. they r well worth it. the handling was my only complaint with this bike . i owned only 2 crotch rockets and this thing is now on parr with them.
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      How comparable are the race tech ones to the ones MikesXS sell? Maybe Phil will chime in... Are they for the same diameter fork tubes? Im j/w b/c Phil is using a set in his FJ forks and has an adapter to make them fit and IIRC he only paied $50 for Mikes...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
        Originally posted by WMarshy
        How comparable are the race tech ones to the ones MikesXS sell? Maybe Phil will chime in... Are they for the same diameter fork tubes? Im j/w b/c Phil is using a set in his FJ forks and has an adapter to make them fit and IIRC he only paid $50 for Mikes...
        The only difference I can see is the RaceTech units are made of brass, while the YSS ones are made of aluminum. Mike's doesn't say what his are made of, they appear to be brass but may be just brass colored. Personally, IMO running soft aluminum (yes, I know the YSS units are 'hard anodized', but that's a pretty thin coating) against the hardened steel of the damper and spring doesn't seem to be a good idea. I can see these wearing out and not maintaining adjustment.
        I believe that RaceTech had a patent on the emulators which has now expired, so that's why you're seeing cheaper copies show up.
        '78E original owner
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          does mikes come with both sets of springs. the 11 needs the yellow 60lb springs
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          led's gallore...
          renthal bars
          vmax tensioner
          Rifle fairing
            The late XS650 has 35mm forks. I'm not sure 650 parts will work in this case.
