i got a 82 xj1100 iam aware of the trans problems with them, i just got it running and in nutral it runs great, so i tried puting it in gear and it rattles, 1 1at or 2nd so i ajusted the clutch, and i got it to go into gear but then it rattles hard so i shut it off.
the bike did sit for a few years. i did notice that its hard to push in gear with the clutch in, like the pltates are sticking. i removed the drain plug and no oil came out? so i removed crank case cover, and tiped the bike sidways to remove oil.
also i noticed someone has been in there becuase the gasket is selfmade.
bike only has 16,000 on it. so i put cover back on and put fresh oil in, i did not change fliter or remove, it becuse i just wanted to see if the oil will break up some of the old.
I re-installed cover fired here up and same thing i did ajust the clutch from down below and up above and got it to go in to gear but it dies, like the clutch is not engaging all the way.
any ideas do you think its sticky plates or bad tranny? it will rattle when i try to put into 1st or 2nd and his hard to get in then if i get it in it rattles real bad, then acouple times i got it in gear and it acted like it wanted to go but i dint so it died.
help i have a bad feeling, why was there a new gasket, bike is real clean did the xj1100 have trans probs with low miles? also why dint the oil drain out drain?
