battery box
  • mack
    • 2411
    • Ontario, Canada
    battery box
    I know there should be some play, but what is normal. I can take mine and shake it back and forth at least a three quarters of an inch at the top. I can't believe the rubber shrank that much. Has anyone ground down the metel sleeves to firm it up a bit?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Can you take a picture Mack. The battery tray shouldn't move around at all are you might be missing some rubbers in there
    BDF Special
    • mack
      • 2411
      • Ontario, Canada
      Maybe
      I can't think what I'm missing I have concave rubber against the frame(face up), metal sleeve, another concave rubber (Facing down)then the metal larger washer and then the bolt. I broke a stud off today trying to tighten it. The metal sleeve that is between the frame and the containment washer seems to be the problem. These concave rubber seats must have shrunk at least a eigth inch each. Is that possible? funny thing, I don't remember it being this loose when I removed it.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
      • Bullet
        • May 2007
        • 185
        • Alliston | Ontario | Canada
        When I was sorting my bits and pieces parts for my XS1100 build the other day ... I noticed something with these spacers ..
        I think there is the same spacer in the speedo cluster mount rubbers as the battery box spacers .. only difference is, the ones for the speedo cluster are longer .. maybe you got the wrong ones installed in the battery box ?
        Just a thought ..
        1980 SG - "Blue Balls"
        Complete Restoration - Finished June 21/2010
        - 1179 kit
        - 80/81 carbs 42.5/115 mains with XS pods
        - Mac 4 into 1 exhaust
        - Venture auto CCT
        - progressive fork springs - no air
        - Mike's progressive rear shocks
        - Galfer S.S. Brake Lines
        - XSDirect - Black Coils
        - 8 mm S.S. Core Plug Wires
        - T.C. fuse box
        - TKat fork brace
        - Geezer regulator
        - Battlax BT45 V-Rated tires
        - 5W40 - Rotella T6 Synth Engine Oil
        - rest of bike is "good old Yamaha"
        • mack
          • 2411
          • Ontario, Canada
          Had a beer
          At the next rally I'll be the guy with a bag over his head. Sat back, had a beer and looked at it. I'd forgotten to take into consideration the upper dampers. I don't have a battery in yet so I'd just attached the box without the cross piece and uppers etc. Got er figured out, sorry to bother anyone.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
          • jmnjrpa
            • Jun 2009
            • 863
            • Lewisville, Texas
            Yeah
            that rubber can shrink. Got some new rear peg rubbers and they were over a 1/4 inch longer! The new ones don't rattle but the old ones about drove me nuts!
            '81 1100 MNS - "Midnight XSpress"
            Original except:
            Big John
