my xs11 specials won't idle down
  • my xs11 specials won't idle down
    I have a 1891 and the sucker won't idle down even w/o the throttle cable hooked up, i don't need the choke to start it then it shoots up to 4.5 to 5 000 rpms might anyone know why?
    If
    You have a 1891 I'm suprised it will run at all!
    Original except:
    Big John
      There's a main idle screw in between carbs 3 and 4. Counterclockwise will lower the idle. Set it with the engine at full operating temperature to 1100 rpms. You might have to crank it down if it's idling that fast, and then might have to go back up a bit when the engine is hot. Then again, aren't the 1891's steam powered?
        sounds like the choke is stuck on
        if not, you need to eyeball the throttle buttrflies to make sure they are shut.
        1980 Yamaha XS1100G Lowered, 4-2 , Pods , Jets
        1973 Triumph TR5T Trophy Trail - almost original
        1973 Plymouth Duster - nothing original
          1891?........reduce water supply....
            Make sure the throttle cable is seated into the engine side connector properly. I had the same problem after cleaning my carbs. The black cable end was not fitted into the slot properly and it took me a while to see it. Keep looking and you'll figure it out. Good luck.
            '81 XS11 LH (MNS)
            "On a scale of 1 to 10, I have an eleven!"
            "Excess is easier to say than XS,"
              thanks for the tip on the 1891 xs (I'm a DA 1981)
              Thank you for the tips and thanks for the grief on the steam engine and so on
