Ok I don't know where to start.. #3 carb is over flowing from air vent so I cleaned the needle and seat, adjusted float hieght and managed to stop the leak for about 5 min. I went in and cleaned all the carbs iternal parts with the dip system reasembled and #3 leaked again. I tried the bench test and blew air thru the gas line while the carbs where upside down and seemed to work... Hooked it back up to the bike and turned petcock to prime, out came the gas.
no leak when in on postion so I choked it and fired her up, the rpm shot staight to 5k. Tried bread-tie method to sync um but I felt like I failed.. Any advice would be inspiring to try again. Thanks xs11 community
