More thoughts and ideas.
Thanks Steve, I did search and find the link to the replacement OEM pistons, but I'm still wanting to do an upgrade of some sort. Was also looking at other types....wondering about the FZR 600 calipers, they are dual piston..but I'm not sure if they are the same size..they look like they used 2 different sized pistons in the same caliper, will check the microfiche soon.
Both the Harleys and the FZR's are solid mounted, do the Harleys use floating discs...do the 90+ FZR's use floating discs? The Harley ones even mounted on the Standards have to be mounted solidly, and so I would expect very close to the rotor at least on the INSIDE edge since the caliper body can NOT float/slide sideways to even it's position while grabbing the rotor??
YES I was/am planning on modding the Specials mount to allow a 2 bolt type configuration to mount an adapter plate to it!
I just checked, and there's quite a bit of space between the inside edge of the OEM caliper body and the spokes, so I'm hoping the FZR's aren't made too wide there so there'll be room for it to be mounted?? Any thoughts, I don't know how I could find the dimensions of the FZR calipers?
