What is you real world experience at adding some grease to the swing arm bearings?
can I do this after removing the cover pivot shaft, collar and oil seal?
What usually has to be replaced?
Tia
Rick
Tia
Rick
I check when changing tires, and it's easy.
. The 72 is for the locknut
Thanks to John, I got replacement shafts but I had to re-tap the frame - Doh!
