Exhaust pipes 3&4 are not heating up?
  • Filter
  • Exhaust pipes 3&4 are not heating up?
    78xs cyliders 3&4 are not fireing???
    79xs11 g
    k&n oval pods
    4-2 jardine spagetti headpipes w reverse short cone
  • #2
    Most likely cause is fuel. 3&4 get fed from your right petcock (typically). On the 78 model you have vacuum operated petcocks, so if the vacuum diaphram is messed up it might not feed fuel. Try turning that patcock to prime and see if it clears up.
    Also look for kinks in the fuel line. Otherwise, you could have a clogged petcock or something liek that, but it is alot less likely.
    • #3
      ok.now its only #4....
      79xs11 g
      k&n oval pods
      • #4
        you might also want to check that
        the mixture screw isnt broken on the number 4 carb.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • #5
          Or at least try adjusting the mix screw to no 4. Or replace/clean the plug in no 4.
          Might also look into cleaning the carbs up then. Once it is down to one cylinder, it is usually a carb issue.
