Clutch acting weird
  • perurider
    • Apr 2010
    • 121
    • Peru, Indiana
    Clutch acting weird
    I took off my clutch cable at the engine(it was crudded up) and cleaned it put it back together, done, or so I thought, it would kill the engine as soon as I shifted it into first, like there wasn't enough clutch, I messd with the adjuster thingy(tech. term) at the motor, forever and at the lever too. I also notice a knockin sound in there now..wjhen you are releasing the clutch and in gear. The adjustment screw is all over too, I adj. it like a thread on here says in to touch and back off an eighth turn, secure nut. But I adjust and doesnt work and look at adj. screw again and it is really tight. like something in a bind. Before anyone says it...I know I should left it alone!! it worked. Thanks for any help.
    '79 XS 1100F
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    With the engine off and the bike in gear can you roll it with the clutch pulled in?
    When you let off the lever does the bike stop rolling?
    The only thing I can think of that could go wrong with the clutch adjust procedure is if one of the "balls" fell out from the back side of the mechanism. You may have to pull the clutch cover off the bike and check it out, but don't do it yet someone may come along with a better suggestion.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      I am guessing one of the balls have fallen out. Thats the only reason I can think that you would have a knocking sound. You can put the bike on the side stand and take the cover off and check to see if they are in place.
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • perurider
        • Apr 2010
        • 121
        • Peru, Indiana
        will I have to worry about trashing the gasket? should I have a gasket before I take off sidecover?
        '79 XS 1100F
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          You will most likely need a gasket after you take the cover off . You can also use many different types of a liquid gasket .
          BDF Special
          • ross
            • Dec 2006
            • 542
            • see signature...
            my ballls, my balls.....
            hey there perurider....your a hoosier and you lost your balls.....d*mnit man....ya can't do that.....here's where they are located.....
            (backside of the clutch housing cover)
            if ya need help, search back on my name.....just did it and can offer advise if you need....ride hard, ride safe....ross
            rebel devil
            1979 xs 1100f standard
            authenic historical vehicle
            42°36'23.52"N, 82°52'44.78"W
            "I'M IN MY HAPPY PLACE"
            "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
            "if you don't wrench on it, get behind me satan!"
            '96 venture cct.....installed!
            stainless, braided, pvc coated brake lines
            i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
            • tinman905
              • Aug 2007
              • 946
              Someday I hope I can learn how to put those red arrows on the pics
              BDF Special
              • dpotter58
                • Aug 2004
                • 1865
                • Southern Maryland
                Open the picture in the paint program and draw anything you would like and save it...
                1980 LG
                1981 LH
                • tinman905
                  • Aug 2007
                  • 946
                  Thanks for that!!!!
                  BDF Special
                  • boediddly
                    • Dec 2009
                    • 50
                    • columbus,oh
                    clutch gasket
                    man, dont use that liquid gasket , before you know it it will be inside your engine blocking your oil passages, getting in your bearings or plugging up your oil pump screen ,like the one I just bought ,and had to rebuild .Do it right and buy a new gasket.Before you put it on put some lithium grease on both sides and then it wont stick if you have to remave it in the immediate future ,and therefore not rip and can be reused .By the way , if you take that cover off and the gasket doesnt rip reuse it.
                    • ross
                      • Dec 2006
                      • 542
                      • see signature...
                      new gasket a must....
                      hey there folks....took me 2 hours of beer, smokes, patience, gentle hand with the chisel to get the original off.....new gasket and blue rtv gasket sealer......sealed up like butter....let set 24 hours and go....
                      ....ride hard, ride safe...ross
                      rebel devil
                        All that junk about RTV getting into everything is bunk in my opinion. I have used it on several auto engines in the past, even for a head gasket on one. Never found it anywhere I did not put it.
                        Now if you decide to cover the gasket surface with a 1/2" layer like making a peanut butter sandwhich and then squeezing it and bolt it up tight as your hand will pull before it even sets up, yeah you will get the crap everywhere in and out of the engine. But, not if you use it as directed.
