Is it possible to remove drive shaft w/o removing rear wheel
  • davestrike
    • Mar 2007
    • 94
    • Tacoma, WA
    Hello All,
    Is it possible to remove the drive shaft and cover without removing the rear wheel?
    I need to remove it due to the entire system being locked. If any of you recall I had the engine/tranny seize and the entire drive train is locked in 5th gear. I need to move the bike so I was thinking about removing the drive shaft w/o having to rear the entire rear end.
    I hope.
    Dave
    Dave
    Tacoma, WA.
    Nope, can't get that puppy out without removing the rear wheel and the final drive. But what you can do is pull back the boot at the middle drive and pull the four bolts connecting the u-joint to the middle drive. This will allow the driveshaft to spin so you can move the bike...
    This will also quickly indicate if it is the engine/trans that's seized or if it's the final drive.
    '78E original owner
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      Long answer: No.
      But you can pull back the rubber boot between the engine and swing arm and take the four bolts out that couple the ujoint yoke to the middle drive. It will take some creative language if the wheel wont turn.
      Ich habe dich nicht gefragt.
      • davestrike
        • Mar 2007
        • 94
        • Tacoma, WA
        Thanks guys. I knew someone would have an answer!
        Dave
        Dave
        Tacoma, WA.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Steve types faster than I.
          • mxmikie
            • Aug 2008
            • 482
            • Bouse az
            you can pull back the rubber boot between the engine and swing arm and take the four bolts out that couple the u-joint yoke to the middle drive.
              What, you only use one finger?!!
              '78E original owner
