Unidentified Relay
  • roll-me-away
    • Jan 2010
    • 14
    • Sayville L.I NY
    Unidentified Relay
    Just cleaning all the electrical connections. I came across a relay underneath
    the fuel tank that I can't identify it has 4 connections a black wire to 86, a white wire to 30, a red-yellow to 85 and a blue wire to 87 there is a jumper between 85 & 87. I cant find this on any wiring diagram. everything else I have identified
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Sounds like a aftermarket relay for a air horn or driving lights .
    BDF Special
      • 8892
      Yep, after market relay. I just put one on mine for the coils, what is your's hooked up to?
      • randy
        • Dec 2003
        • 4521
        Yup, standard aftermarket relay. The jumper between 85 and 87 will cause it to latch. My bet is that the PO replaced the headlight relay with a standard aftermarket.
        • roll-me-away
          • Jan 2010
          • 14
          • Sayville L.I NY
          Headlamp relay
          Sure looks like replacement for headlamp relay. Why the jumper? What happens if I leave the jumper off? I liked the idea of using an aftermarket relay to power the coils with battery voltage seems that would eliminate weak spark issues.
          • psycoreefer
            • Feb 2008
            • 1557
            • Minden, NV
            As randy stated the jumper will make it "latch" so once the bike starts the headlight will stay on until you turn off the key, just like the factory relay. If you take the jumper off then if the bike were to stall, the headlight would go out.
            My question for those in the know, does the fact that there is no diode in that jumper(i'm assuming) cause any issues? Isn't that trigger wire hooked to AC current from the stator?
            1979 xs1100 Special -
            My Bike:
            [link is broken]
