I need to know the shaft spline pattern to finalize the adapter drawing....hopefully we have a gear cutter on board....
Hi XSchop,
as has been posted, outside splines are easy but inside splines are a bitch unless you can justify coming up with the price of a broach.
For a one-off part we cut an outside spline from brass bar and used it as a form tool in an EDM.
