I'm trying to sync my carbs and it is going like crap as usual.
I can cync the vacuum just fine except for the ghost making the reading change at erratic times. But I eventually get it. When I try to adjust my pilot screws the tach and sound of the engine is to minor for me to detect. I've got it idling as low as possible to detect a change and there is about 1.5 revolutions of play in the screw between when it ramps up and down. That's just not accurate enough for me. I have a Solid State electronic Tach/Dwell Voltmeter to hook up but can't remember how. It has a smaller green pinch connector and a larger black pinch connector. I want to use the tach on it since it is much more accurate. Does anyone do this or know how to hook it up?
I posted about verifying that you have an 81 MNS vs. an 80, or the carbs from an 81 at the least!?
