Signal light canceller
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Hey Folks,
    I was looking around for another headlight modulator for my J, have one on the G, and ran accross this from the same company.
    MSRP is a bit high at $100 but they can be had on ebay for less. Yet, as rare as the OEM cancellers are, and expensive when you find them, I think these may offer and option. No one likes to ride down the road with a signal light blinking and announcing that our internal gasses are coming out the wrong end......
    https://www.kisantech.com/view_product.php?product=SM-1
    The cancellers on both my rides are working but should they ever fail.....
    Let me know if you think these wil work.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    As you pointed out, a bit pricey...
    Sure, these would work, but they won't quite duplicate the factory unit. The OEM piece uses a time and distance calculation (with input from the speedo) to determine when to shut off the signals, this unit only does time. A simple 12v relay with delay-on-off would do the same thing and give you more choices on the amount of time, such as this:
    Less money for the same basic feature, although this isn't a plug-and-play switch; some wiring will be needed. If you want the other features they're offering or the ease of plug-in install, then it's not too bad a deal.
    '78E original owner
    • Cobia
      • Jul 2007
      • 1587
      Definitely more akin to my budget. Yet, although I'm mechanically adept, electrically I can be classified as barely competent. If someone drew out a diagram on how it should be wired, I could definitely execute it.
      As I mentioned, both of mine are working so I don't have these issues, I was just passing along the information.
      Even when I was using a typical two prong flasher from the auto store I developed the habit of turning it off after the turn was completed....... and kept those internal gases flowing in the right direction.
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      '82 XJ1100 (Sold)
        • 1372
        Cancelled Options
        Although the OEM cancelling relay may be as hard to find as a living, breathing, dodo I believe it's actual function shouldn't be that hard to duplicate.
        Although it may be a solid-state device, it's function is very similar to this:
        (A DPDT relay...)
        Which looks like this in real life:
        (Notice the same 5 pin-outs as the OEM canceler...)
        I'd say that if my canceler went Tango Uniform and I couldn't find another one, then I'd adapt something like this to work. That way I'd retain the original bikes wiring up to the connector with a different pigtail on the end. This arrangement would also use the function of latching into the on/enable when the handlebar switch was actuated and then using the same switch in the speedometer to unlatch the relay when the speed/distance was achieved.
        Alas, Cobia. My canceler is in perfect working order so this "mod" isn't yet on my to do list.
        Besides, anything I could come up with would be far surpassed by what Geezer would design and offer for resale. I mean he wouldn't fuss around: likely that his unit would be entirely solid-state and guaranteed for life.
        I know when not to compete with such greatness.
