Hi XSives,
My bike has been sitting awhile. It seems to only run on 4 cylinders in the high RPMS, otherwise it seems that number 4 is crapping out. I yanked the carbs and they all have fuel, but it looks like #3 and #4 fuel feed (fuel filter) doesn't ever have any fuel in it. There was fuel in the bowl but not in the filter... I blew through the passageways and get air coming through the needle valve assembly.... Spark plug looks like it's burning some fuel. The reason I know it's not firing at least on low rpms is because I can remove the plug cap and there is no change in engine rpm or performance..... Bad pilot circuit?
With the carbs off and with it being dark, I can shine a flashlight into the intakes and can see the valves. 1-4 have a lot of black crud on the valve surface. I can't see that the stem is wet with oil or not, but #1 looks cruddier than the others. What is a "normal" amount of crud on a valve? Should there be much if any at all? How much are valves and guides each? I already have stem seals........
Ben
Ben
