I posted this message a while back and just now had time to check my bike out.
"I have a 1981 xs1100 motor with 12000 miles on it. The motor set for a while and I installed it on my 1980 xs1100sg frame. All the extras like carbs were off previuos good running engine with 70000 miles. I wanted to take the old one off before it was not usable for parts.
The 1981 motor started right up and idles perfect. It has no ticks or knocks. My question is the engine will rev up to around 3500 rpms and then doesn't want to go any higher (just bogs down until 3500 or lower) and I wanted a second opinion. It also has good power until the 3500 or so is reached.
I tried taking off and on the vacuum to the distributer and there is very little change. I considered setting time but wanted to ask you guys first.
thanks wayne"
I wanted to thank everybody for their input and report that the ones which told me the distributor needed changed were right. I replaced the distributor on the 81 motor with my old 80 one and it ran almost perfect as soon as I hit the switch. It was almost plug and play since the bike had been ridden everyday and even carbs plugged and played.
Thanks wayne
thanks wayne"
Thanks wayne
