Attention Houston, we have a problem!
  • 1sttimeXSowner
    • Aug 2009
    • 33
    Well, the weather here in good old GA has been great and I have enjoyed riding for the past several days...until yesterday that is. Rode to work yesterday AM--all was great; got on the XJ to come home last night--it started but I forgot to use the choke and as I pulled off I stalled! Now, it won't do a thing--no lights, sound...nothing! Checked fuse but not blown, checked battery but it's charged.....any help???????????????????????????
    1982 XJ1100J; 2006 Suzuki Boulevard C50
    Athens GA
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." -Benjamin Franklin
    Hmm...is your starter turning over? If you pull the plugs, are they wet or dry?
    Lets run through some easy duhh type stuff like petcocks are on, the emergency shutoff switch on the right handlebar did not get bumped to off when it stalled, you have the bike in Neutral or clutch pulled in?
    • psycoreefer
      • Feb 2008
      • 1557
      • Minden, NV
      You say you "checked fuse" which one? I don't know for sure about xj's but the xs's and many other bikes have a "main" fuse that is not in the fuse panel. It should be a 30 amp fuse, even if it looks good replace it just to be sure.
      Check the stuff DG mentioned too
      1979 xs1100 Special -
      My Bike:
      [link is broken]
      • Cobia
        • Jul 2007
        • 1587
        • Palm Beach County, Fl
        The main fuse on the XJ is toward the top rear section of the battery compartment under the seat. Same thing happened to me once, not the stalling but the "nothing happeneing" when I pushed the starter button.
        That fuse holder doesn't look like a typical one either. It's kind of flat because it can also store a spare fuse.
        1980G Standard, Restored
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        1980GH Special, Restored
        '82 XJ1100 (Sold)
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          Do the XJ's have the fuse on the LEFT side of the bike from the battery under the side cover like the XS's???
          I know mine was blown under that cover.....replaced it and everything else worked okay...
          '81H (my first XS ) "Grey Ghost"
          4:1 Jardine w/ headerwrap
          Windjammer(wiring issues)
          New paint/brakes to come!!
          '80G FrankenBike (parts bike)
          '80G to fix "BlackSunshine"
          Stock Pilots/125 mains
          Pod filters; 4:1 Kerker??
          SS Brake lines w/ new M/C's
          LED Brake Lite
          Needs paint....
            Yet another reason to switch to the ATC fuses, and move the main fuse to that new panel. I also use fuses that light up when they are blown to help in locating them in the dark. I got them at AutoZone.
            • jmnjrpa
              • Jun 2009
              • 863
              • Lewisville, Texas
              Check
              your KILL switch. Not just to see if it is off but if it has contact.
              '81 1100 MNS - "Midnight XSpress"
              Original except:
              Big John
              • XJOK2PLAY
                • 2099
                • Skiatook, Ok.
                Kill switch bumped or in gear... must be in neutral on the XJ...
                2 quickest things I can think of before it gets deep... also, in gear, kickstand down? Or I've seen the bolt on the kickstand switch get loose and the switch turn enough it kills the bike.
                2011 Kaw Concours 14 ABS
