i ran the bike and all is good except for no 4 cylinder, i did the spray test on all and number 4 is running cold, i pulled the plug and replaced it with another, checked for spark , good there, checked the carb for fuel and all is good, what would cause one cylinder not to run hot, the wires are decent and in good shape, im running accell coils and wires. this all started when my carbs had to go due to all the air mixture holes were in bad shape ,i bought another set of carbs went over them for the clean up and check, they run better than my old ones except for this problem that came up, noticed it didnt have the smoothness and response that it should and that no 4 did not pass the spray test
