ncback
  • Filter
  • ncback
    How can i find out if my xs1100 is an sf, f etc?
  • #2
    What's the first few numbers from the VIN?
    • #3
      ncback
      The first couple digits of the vin are 2H700
      • #4
        Check out this thread on VIN Decode
        http://www.xs11.com/forum/showthread...identification
        1980 XS 1100SG
        Dyna 3 Ohm Hi Output Coils
        Pod Filters
        DynoJet Kit
        T.C.'s Fuse Block
        V-Max Auto CCT
        • #5
          You'll find the VIN number on your motor right above your clutch cover.. and also on the left side of the steering neck (Triple tree) on a placard.. and stamped into the metal on the right side of the steering neck. Do those numbers match the motor? If so, it appears your "F" may be an "E" ('78)
          It will officially go by the numbers on your steering neck..
          • #6
            ncback
            The first few digits of the vin are 2H7005
            • #7
              Sounds like you have a 78 there. Pictures are always helpfull. As old as alot of these bikes are and as many owners as they have been through, ,any of them have had parts switched out from one type to another, effectionately known as "Frankenbikes".
              • #8
                Hey now...i resemble that last post!
                I saw one the other day that had special forks, standard tank, special guages and some home made rear end. looked okay, but those that have seen these bikes do a double take and think..."WTF".
                '81H (my first XS ) "Grey Ghost"
                4:1 Jardine w/ headerwrap
                Windjammer(wiring issues)
                New paint/brakes to come!!
                '80G FrankenBike (parts bike)
                '80G to fix "BlackSunshine"
                Stock Pilots/125 mains
                Pod filters; 4:1 Kerker??
                SS Brake lines w/ new M/C's
                LED Brake Lite
                Needs paint....
