Right Blinker Light Stays On
  • thewright1
    • Aug 2009
    • 198
    • Orange County CA
    Hi All,
    I just tried adding on a new blinker to the right side of my bike and I noticed that when I turn the right blinker on, the light just stays on. It blinks once, but then it doesn't blink again. I was thinking it had something to do with my ground wire, but when I remove it, it doesn't turn on at all. Is there something that I'm doing wrong or is there something that I need to adjust?
    1980 XS1100SG
    In the process of making her look pretty!
    P.S., TomRodgers has the best avatar icon ever!
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    We need more info....
    You say you tried adding a blinker, so did you leave the two stock blinkers on? Or are you replacing the stock blinkers with something else?
    Do the blinkers on the left side still work?
    Is your new blinker LED or standard bulbs?
    My best guess without answers to those questions is that your new blinker doesn't draw enough current to make the stock flasher unit work. Try picking up an electronic 2 prong flasher form the auto parts store and putting it in place of the stock one and see if it blinks.
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      When you say you "added a new blinker", do you mean the flasher relay, or the light bulb/fixture itself?
      • mro
        • 4276
        • Hayward, California
        Most of the time when the turns don't blink ...
        corroded grounds/connectors
        corroded bulb socket
        low voltage
        faulty flasher
        wrong bulbs or flashers installed
        handle bar switch corroded
        mro
        BTW, does the 4 way work?
          +1 what mro states! Take the time to meticulously go through all those checks.
          • thewright1
            • Aug 2009
            • 198
            • Orange County CA
            What's up everyone. Thanks for all the great responses. Just to give a little more detail. I didn't actually "add" a right blinker, the term I should have used is "swapped". I took the old one off, and put a smaller one that I bought from cycle gear http://www.cyclegear.com/spgm.cfm?L1...tem=FAI_2522_G
            The lights are standard bulbs. I changed the ground connector and the handle bar switch is brand new (from Mikes XS).
            As stated earlier, my guess is one of the three:
            low voltage
            faulty flasher
            But I will try picking up an electronic 2 prong flasher to see if I can get some love with that. Thanks for the help everyone.
            1980 XS1100SG
            • thewright1
              • Aug 2009
              • 198
              • Orange County CA
              I should have asked this earlier, but should the 2 prong flash be 12.8V as well? I also noticed the existing flasher unit has 3 prongs (the long cylinder(ish) looking one), am I looking at the correct item? Just wanna be sure I'm on the same page.
              1980 XS1100SG
              • Luxury
                • Jun 2004
                • 57
                • Chippewa Falls, WI
                You're on the right page - the stock flasher is 3-prong. The 3rd prong is for the self-cancelling feature, which you will lose with the 2-prong. I have a Tridon EL-12 flasher that works well with my LED turn signals. I think I got it at Advance or O'Reilly. You'll have to experiment to figure out which way it fits in the connector (if you get it wrong the first time it will not cause any damage).
                Frank
                1979 XS1100F Street Rat
                • thewright1
                  • Aug 2009
                  • 198
                  • Orange County CA
                  Cool, and did your wiring stay the same, or did you do something special with that?
                  1980 XS1100SG
                  • Luxury
                    • Jun 2004
                    • 57
                    No wiring changes are necessary.
                    Frank
                    • thewright1
                      • Aug 2009
                      • 198
                      • Orange County CA
                      Cool, well LED's it is then. I'll try that out and let you guys know my results.
                      1980 XS1100SG
                      • thewright1
                        • Aug 2009
                        • 198
                        • Orange County CA
                        Just got my LEDs in the mail yesterday. So I'm gonna head over to Kragens later on today to pick up the Tridon EL12 Flasher. If they don't have that specific model, is there another one that I can get from there?
                        1980 XS1100SG
                        • Luxury
                          • Jun 2004
                          • 57
                          Any 2-prong electronic flasher should work. Just make sure it's electronic. Mechanical is cheaper but will not work.
                          Frank
                          • thewright1
                            • Aug 2009
                            • 198
                            • Orange County CA
                            Perfect, thanks for the info. Do i need to remove the headlight to remove the front blinkers?
                            1980 XS1100SG
                            • Luxury
                              • Jun 2004
                              • 57
                              Standard=no. I believe special=yes.
                              Frank
