Hey all....
Well just finished rebuilding calipers. Pistons were A-O-K, no pits, no rust, no scores....
Back to the original problem with 'Sunshine now. I may have FUBAR the new M/C.
I re-bench bled the m/c. but after the air came rushing out the first time (after about 5 'bleed' cycles), NO pressure from squeezing the handle...with the cover off, i WAS seeing tiny airbubbles coming up from the 'spooge' hole. put first banjo bolt on and started the process.....at first i got a $hit load of air from the calipers.....then fluid....then nothing...NO pressure. I started over again....'bled' the first joint at the M/C. some air...then fluid....second joint at top of splitter...some air....then fluid....didnt do the double banjo, cuz i snapped the last one off if you remember....back to the calipers....tiny bubbles, but thats it....STILL no pressure and the calipers still "floppy" on the rotors....
Im wondering if i didnt mess up the plunger seal in the m/c.... but after leaving it a bit, i get air back up the 'spooge hole'.....
Mind you, pistons went in okay...lubed them with DOT3, and slid them in...then POP the rest of the way....and it rotated and slid around okay.
Any ideas? i dont have a mighty vac.....74 degrees today...80 tomorrow...and a VERY favorable weekend forecast......these brakes are the ONLY thing keeping me from getting 'Sunshine out there to see if there are any other issues!!!!!
HELP!!!
HELP!!!
