XS bearings??
  • helichuck
    • Mar 2010
    • 2
    XS bearings??
    Hi there,
    I have an XS1100 that locked up on my son-in-law.
    It was torn down and we are told the the bearings are out of the middle unit and that you can't get them anymore.
    Is that true??
    If not true, then where ??
    Thanks,
    Chuck
  • dpotter58
    • Aug 2004
    • 1865
    • Southern Maryland
    middle drive unit? lots of pieces and parts out there pretty cheap.
    1980 LG
    1981 LH
      Hey Chuck,
      What Potter's saying is that the middle Drive unit is fairly complex, takes some special tools and such to work/repair/ adjust properly. Also, if locked up, then aside from the bearings, the shafts and gears may have also suffered damage.
      SO...lots of folks parting bikes out on ebay, so you can usually find a replacement middle drive quicker, cheaper, than trying to have the one that's frozen up worked on!
      The one that froze up....had he checked it for oil? They can sometimes leak, and when they run dry, they seize. Folks sometimes drain that bolt thinking it's the ENGINE drain. Takes about 300cc's of 80-90wt hypoid type gear oil, can be dino or synthetic. It can be removed and replaced without pulling the engine.
        If the middle drive is in fact the problem.....several of them on e-bay for less than 30bucks, plus some menbers here have extras that they may be willing to part with to help get your scoot back rollin' again.
        • helichuck
          • Mar 2010
          • 2
          Thanks
          Hey guys thanks for the info.
          I just did a search on ebay and can't find one for less that 85 shipped.
          If someone has one for a good price let me know,
          Chuck
          • tarzan
            • 1700
            • Chandler,Az.
            Here is one.
            http://cgi.ebay.com/MIDDLE-DRIVE-UNI...item335a2d80b4
            I also have one from an '77 XS750. I think that would work.You would need to check with the experts here first though. $30 + shipping.
            80 SG XS1100
            14 Victory Cross Country
              Check the 750 real close for bolt pattern. It may be one bolt short when compared to the xs11. I had one from ebay that was NOT from an xs11 (not sure what it was from) and it was obvious that from looking at the cap, it was one bolt too few. I did try it and it weeped oil.
              Originally posted by tarzan
              Here is one.
