hey guys, just changed my fluids today, went to torque the final drive drain bolt to 17flbs but it just keeps going round and round, did i wreak the threads? it wont come out either now
1979 XS1100SF 37000km
Green Dyna Coils
Stainless Brake Lines
Sight unsdeen, it sounds to me like you have stripped threads. Look inside the hole with a small mirror to see. If you need to repair the threads then you can remove the final drive and perhaps tap the hole the next size up and use a larger bolt and copper washer to make a new drain plug. Any cuttings from re-threading should be minimal and would not hurt anything inside the final drive since they will be small pieces of aluminum and all the gearing is steel.
Mike Giroir
79 XS-1100 Special
Just take the plug to an ACE hardware or something that has the bolt assortments. Find a fine thread bolt that's just a touch bigger.. standard or metric.. and I would even spring the extra buck for stainless if it was me. Then go by just about any auto parts store and buy a crush washer (That's the copper washer tadracer mentioned) that fits that bolt. Those washers are usually in a metal bin behind the counter with the other brake parts. That aluminum is pretty soft and threads easily.
BUT.. I wouldn't get too awefully involved in it. You can probably pick up another F/D for 25 or 30 bucks.... or less.
LOL.. Yeah those four 12mm nuts that hold it on play heck with people..
What do you need the 17mm socket for? Unless you're talking about the shock nut. I forgot about that.
Hee hee.... I type faster than a cripple! Woo hoo!!
Heck, I'm still typing two handed, I just can't lift any weight with the arm. So alot of other things are onehanded these days. Its surprising how much you can miss switching hands sometimes.
IF you have a centerstand and a jack stand to prop under the front frame rail, you can pull one of these bikes down to nothing but the frame. No jack required.
On my specials, I can put it on the centerstand, remove the rear wheel and then turn it on an angle and slide it out without even loosening or raising the rear fender.
Pretty damned impressive for a one-armed guy, Don!!
