I've hit a snag putting the saddlebags on my XS with the XJ air shocks.
The air crossover line male connector needs to be replaced with a 45° elbow because the air shock crossover line is too close to the saddlebag mounting bracket.
![](http://farm5.static.flickr.com/4049/4473605871_21e72c8045_m.jpg)
If I hit a bump it's going to snap the connector or, more likely, break the fitting out of the top of the aluminum shock.
Here's the current connector. I believe it is a JIS 3/8" - 19 with 60° cone x 5/16" -19 BSPT with o-ring face.
![](http://farm3.static.flickr.com/2768/4473608719_a567c57edf.jpg)
I may have located a replacement I can make work but it's 3/8" -19 x 3/8" - 19 with no o-ring so I'd have to drill and tap the top of the air shock and fit an o-ring to the elbow:
Parker 6V3P4
45° Male Elbow
60° Cone / BSPT
![](http://farm3.static.flickr.com/2731/4474542176_dcfbfb3424_o.png)
If I removed the helmet lock and ground off it's mounting tab I could put the shocks on without the 45° elbow BUT that would put the Schrader valve behind the saddlebag. It would be almost impossible to put air in the shocks.
I could put Schrader valves on both shocks and eliminate the crossover line but that would be almost as annoying as removing the saddlebag to fill the shocks.
So, today I'm waiting for an email reply from the good people at the Parker Hannifin Corporation in Columbus, Ohio to see if they have a fitting I can use.
Onward and upward!![Big Grin](https://xs11.club/core/images/smilies/biggrin.png)
Regards,
Scott
Parker 6V3P4
45° Male Elbow
60° Cone / BSPT
Onward and upward!
Regards,
Scott
