Okay, I've been chasing this problem ever since I bought my bike. Every now and then, the tach decides to just up and quit working. Usually it's only for a few seconds, but sometimes it takes a while to finally "wake up" and get going again.
Because it's all connected, I'm sure my battery charging system is taking a hit every time this happens, too. It's never usually a big problem, as it's never "off" long enough to cause issues.
I've checked the connections behind the fuse panel and one (the two-wire one) WAS loose (when I had the bike on and jiggled the wires there was a nice little blue light show in the connector, along with the assorted pops and crackles...
). I thought I fixed the problem, but this season it cropped up again. Problem is, whenever I jiggle the connections looking for a loose wire while the bike is running (not the best idea, probably), I can't get the tach to quit.
What's weird is that I've noticed something new this time around. When the tach isn't working, the bike actually seems to run better. Revs pick up a bit and the engine seems to run a bit smoother. When the tach pops back on, the engine settles back down again.
Any thoughts, advice, words of wisdom? Thanks.
