Valve Shim help
  • Rudy
    • Aug 2009
    • 12
    • Lincoln, NE
    Valve Shim help
    So I finally took some measurements on my valves. here are the results:
    1 2 3 4
    E .127 .178 .127 .178
    I .063 .076 .102 .076
    My question is, what should they be and how far off am I right now. Could this be the cause of excess smoke in 1 or 2? I still need to go through the carbs but I thought I would check the valves before I get to that point. Thanks guys I know this has been beat to death but I can't find the stock clearances when using the search feature.
    Also does anyone have a spare front caliper piston for cheap? Cheapest I found was $26. The one I have was frozen and pitted pretty bad. I assume if I use the pitted one I risk the chance of it leaking...
    1978 xs1100
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Are those the valve clearance numbers or the shim sizes? If those are the clearance numbers that's a lot of clearance. If you find one of CatatonicBugs posts, he has the manuals available from download through a link to his website in his posts. Be aware, they are rather large, but they have all the information in there.
    Also, in order to know what to tell you, we need to know what year and model, as they differ. But in either case if those are the gap, I think that's too much clearance.
    • Rudy
      • Aug 2009
      • 12
      • Lincoln, NE
      These are the clearances....
      1978 xs1100
      • Rudy
        • Aug 2009
        • 12
        • Lincoln, NE
        Okay so I found the clearances
        E .21-.25mm
        I .16-.20 mm
        Please correct me if I'm wrong but I need more clearance on Intake and Exhaust.
        1978 xs1100
          Here's the easiest way to check valve clearance, IMHO. Going to be using inches here, not mm.
          Intake: .006"-.008"
          Exhaust: .008"-.010"
          First, measure your clearances in inches with the engine cold and write them down. If they are in the range, you're fine. If they are off, remove the shim and look at the number on the bottom side. Each increment of shim size is .002" in thickness. For example, if one of your intake valve measures .005" and the shim says 280 on it, you'll need one size smaller shim to open the gap up to .007" which would be a 275 shim. This is the way I check valve clearances, it's dead on accurate and no charts to fool with. HTH
          • Rudy
            • Aug 2009
            • 12
            • Lincoln, NE
            Thanks for the help fellas. Still looking for a caliper piston if there are any floating around. I may just break down and buy one.
            1978 xs1100
              I saw a guy on Ebay making and selling stainless steel ones... that would be your best bet. I'm sure someone has one, but it will be steel that's been exposed for 30 years now. Probably good enough to work still... but???
              And Phil...
              Prometheus says this is easier for him also... just never understood why you need to convert to standard? I can count by fives just as easy as counting by twos?
              Just my 2 cents.
                Tod, I'm not doing any converting at all. Just taking an easy measurment ex: .013" take away 2 at a time while counting on your fingers would be 3 shim sizes larger to get a gap of .007. All simple math with small numbers, no converting. I don't use the shim size as a metric measurement, only a reference number. I did learn this from Prom's posts BTW, much easier for me. It was a tad confusing at first but now it's a no brainer.
                  That would be this thread:http://www.xs11.com/forum/showthread...+brake+pistons
                  I got and installed my set and couldn't be more pleased. No more rust for me...
                  '78E original owner
                  • Yard Dogg
                    • Mar 2010
                    • 884
                    • Tri-Cities, Wa
                    Maybe I missed if you told us your year of bike, but the valve clearance specs changed in '80. On 79's and older the clearance is 0.16 - 0.20mm, starting in '80 the valve clearance changed to 0.11 - 0.15mm. This is assuming your bike is an XS1100 and not an XJ, I wouldn't know the difference if that is the case.
                      E .21-.25mm
                      I .16-.20 mm
                      Yard Dogg, I asked him and he really didn't say what year, but he listed the above clearances which would be for the early 78-9 XS head. We probably got him all confused with the different ways of measuring.
                      • randy
                        • Dec 2003
                        • 4521
                        Yeah, I think you confused the hell out of me! I use a metric go-no-go feeler gauge and the chart. Does that mean I'm a geek?
                        • WMarshy
                          • Apr 2009
                          • 2402
                          • Mexico NY
                          what?
                          Can you clearify for the people (me) who have no idea what your talking about? Also, can the shims be taken out without removing the cams, just need a valve spring compressor right?
                          Do the shims come in some standard size increment?
                          '79 XS11 F
                          Stock except K&N
                          '79 XS11 SF
                          Stock, no title.
                          '84 Chevy K-10 "Big Blue"
                            The service manual (clymer) lists the clearances in inches also, so there's no converting to mm, I just use the inch values. The shims can be removed with the well respected valve shim tool , or the cam's can be removed, your choice. IIRC, there is another method with a different tool, can't remember tho. The shim thicknesses increase in increments of .002" if you are using the English system. Less numbers to fool with when dealing with round thousandths of an inch. I'll search for a few threads explaining it better to really confuse youz guys.
                              Prom explains it pretty well, read posts 9 and 12....
