Last weekend I started the job of taking out the transmission to do the "Black and Decker" fix on the dogs of 2nd and 4th gears. Anyways, after removing the clutch I found what appeared to be a bolt (it had been wore down horribly and damaged). After scratching my head for a minute I began to see the wear marks in the case from where the countershaft bolt had backed out and been ground down from the spinning of the transmission. Maybe this is why the guy I bought it from was having "shifting issues". The bolt head had been completely honed into a point and only a 1/4 inch of threads were still visible along the bolt shaft. The rest had been mangled.
As my luck has it, I have been able to find the part number from Yamaha, but it seems NOBODY carries this one bolt (which has been used in many different models of Yamahas).
Yamaha Bolt
SKU:90105-10085-00
Bolt, Washer Based
If anybody knows better places to look than I please please please let me know.
I wouldn't mind finding a metric bolt either to replace it, however I don't know the size of the original bolt and the threading. What I have left to go off of isn't much.
Yamaha Bolt
SKU:90105-10085-00
Bolt, Washer Based
