Hi,
I have posted a thread here before about my bike running lean or experiencing fuel starvation at high speed. Then I found my idling screw tips broke off in two of the carbs.
Ok all of that is fixed now and I am still experiencing the problem. I have balanced the carbs and set the mixture to a point where it idles with no problem. The trouble comes in when you open it up. It stutters and shoots blue flames (long angry ones) when I close the throttle.
Just to give you some background, the bike is a '78 XS special with the old style carbs with the brass idle screws, all stock jetting. A K&N filter inside the standard airbox and a four-in-one exhaust.
My question is, if I have a 4H0 (I think) TCI box with the vacuum advance connected, what will be the result? I bought the replacement TCI because the original was not working. And I read on the guy that rebuilt "Swamp Thing"'s website that the original used to be 2H7 and the 4H0 has the advance built into the TCI. That would mean that it is advancing the timing two times when under load or when does the advance start working. By the way, when exactly does the advance start to work. I can see the advance moving when I rev the bike up, but as soon as it starts moving the engine starts to misfire.
Thanks
Thanks
