I noticed that my fourth gear consistently misses. I am using Rotella 15W-40. The carbs are getting out of synch - the engine idles at 2,500 when the engine gets hot. (I lost faith in professional motorcycle mechanics. I just ordered the Carbtune synch gauge today so that I can synch myself)
- Did anybody else have the same problem?
- What do you think is causing the fake neutral at the fourth gear?
- Are the clutch plate in need of replacement?
Anyway make sure your fork with the #1 on it is close to the shift lever if you have ever had them out.
