Hey guys, I finally got this 81 I picked up started up and running, one small problem. The throttle doesn't seem to close fully by its self. What I mean is that if I adjust the main idle screw "out" far enough to get around 1000rpm idle then when I rev it and let go it will return to around 1500 - 2000, if I take a long screw driver and gently push down on the linkage the idle will then return to where I set it, but then slowly creep back up once the pressure is removed.
When I had the carbs off for cleaning the butterfly on #4 was initially stuck closed, but after freeing it with a little heat and PB blaster everything seemed to work smooth and free. Also the throttle cable on the bike seemed to work very easily and visually looks to be new.
I have checked that the linkage isn't hanging up on any of the clamps for the carb boots, been there and done that before.
As you can imagine this makes it hard to get a perfect synch and idle mix adjustment.
Anyone else ever had a similar problem?
