Could somebody kindly confirm the size of the rear axle nut? My 24mm wrench head was too small. Is it 27mm, or something odder? I would rather get the wrench head of the right size without risking standing in return and exchange line.
Rear axle nut size
It's large adjustable (Crescent) wrench sized...
Lucky coincidence
Originally posted by randy View PostRear is 27mm. You should have the wrench in the factory tool kit.
that frail bent sheetmetal thing's only use is as a guide to the right size of wrench.
But dont, you are in luck. a 27mm wrench is the exact same size as a 1-1/16" wrench, perhaps you already have one of those?Fred Hill, S'toon
Crescent
Is that a metric or american crescent?78 XS1100E Standard
Coca Cola Red
Hooker Headers
http://i408.photobucket.com/albums/p...m/DSC00580.jpg
1979 XS1100 Special
http://i408.photobucket.com/albums/p...m/DSC00612.jpg
1980 XS Standard
http://i408.photobucket.com/albums/p...m/DSC01137.jpg
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpg
Factory tool kit! So used to not using the factory tool kit...Thanks!
BTW, the factory tool kit for this bike is too good to come with a bike.. I could almost visualize Yamaha engineers grinding their teeth to make the bike and tools better than BMW's.dontlikeoc
1981 XS1100 Special Edition
Alhambra, CA
Metric or Standard...
You guys are idiots. Everybody knows it will work for any size... but you do have to get both a right handed and left handed one to either tighten or loosen those nuts.
Don't worry about it. Those axle bolts are always German torqued anyway.. Gootentight. No matter what you tighten them to, you still have to get the cotter pin to line up... so there goes the torque spec out the window.
